Ask for update BEFORE password prompt
ajgyomber
Post by ajgyomber »
We have UVK password protected. I would love to have it update before asking for the password prompt so we aren't typing in the password twice.
Thanks,
AJ
Re: Ask for update BEFORE password prompt
The version check is an asynchronous operation that begins immediately when the application starts. While UVK is loading essential components, the version update check is done in a separate thread. The update prompt is made when all UI components are loaded and the Window is shown, long after the password prompt.
So the only way to achieve this is to move the password prompt to after the update prompt, when the window is visible. If this does not bother anyone else, I can do that.
or maybe there's a way to not ask for password after update since it has already been asked before
