New features adjustment...
"Added a new Pre-repair action to the System repair list: Disable the User Account Control. This new option allows you to disable the UAC during the repair operation. The UAC can be automatically re-enabled unce the repair operation os complete with the new Enable the User Account Control post-repair option."
Could this, and the Auto-logon, features revert the settings ONLY if the first part changed them in the first place? So, if UAC was already disabled, it's not re-enabled later. Or if the client was already set to be logged in automatically, that's not undone by UVK?
I like disabling UAC as part of the process so that UVK can restart itself on reboot without needing interaction but, if a customer has a PC set his way, I don't want to deal with follow-up calls because UVK changed a setting unnecessarily.
