I’m not sure when this started but I’m getting an error resetting IE and internet settings using ver. 6.9.6.0 in manual mode. It’s on Windows 8.1 x64.
PS: It tried it after rebooting and with SAS and MBam both disabled.
Error resetting IE and internet settings
- Fred.PNG (130.93 KiB) Viewed 1354 times
Re: Error resetting IE and internet settings
Thanks Bill. I'll check that out.
I think that UVK isn’t Un-immunizing correctly because I just figured out if I Un-immunize in the system immunization tab manually all is well but if I Un-immunize with the check box using system repair I get the error.
Thanks, that should help a lot to find the issue.
I found the bug. It wasn't with the immunization. I'm planning on releasing the stable version tomorrow.
