The default settings on Execute prevent prevents some network functions of Quickbooks. This is serious as one of the things it blocks is the credit card processing connection.
Also, it seems it may block pandora as well.
The pandora I am not 100% sure on but it does block Quickbooks. Can you look into that and maybe change the defaults of that tool?
Quickbooks
Quickbooks
Re: Quickbooks
Hi Jim. If those programs install in the appdata directories instead of of the program files directory, which is where all programs should be installed, the it is normal they get blocked.
I created the "List affected files" button to allow you to scan the affected programs and add the ones you don't want to block to the exclusions list. Have you used that feature yet?
Re: Quickbooks
I did not try that one but if I get another chance I will. However, Quickbooks is perfectly legit and common business software that really shouldn't do anything to be blocked yet that part of the software does block it for some reason.
Re: Quickbooks
Execute prevent does not check if the programs are legit. It just prevents all programs from being executed in certain directories, except the exclusions.
Malware and PUPs usually install in the appdata folders, for instance. If Execute prevent is enabled, they will not run. And obviously, all other programs (not excluded) won't run either, even if they are legit.
The "List affected files" feature allows you to quickly detect the legit ones and exclude their directories. If you send me the path where those programs are installed, I can make UVK add them to the default exclusions.
Re: Quickbooks
I will see what I can do there and get that info for you.
