Fred I have info on a crash for you.
It is crashing on invalid file extensions.
I am including an image of the crash and a list of the extensions UVK found with a link to the reg export so you can compare.
Reg file:
http://www.wcsbg.com/downloads/PruntyFileAssoc.reg
System booster bug
System booster bug
- System_errors Prunty.txt
- Export from UVK
- (81.33 KiB) Downloaded 163 times
Re: System booster bug
Hi Jim. Thanks for reporting. I'll check that out today.
I was wondering... If UVK crashed, how were you able to export the list of errors?
I ran it again but did not have it clean what it found. It was only crashing on the file extensions so if I unchecked them it worked just fine.
Oh, so it crashed while removing the registry entries.
You didn't mention that in the first message, so I assumed it was during the scan.
Sorry I didn't mention that cause I thought I uploaded a pic of the crash but it didn't seem to make there. The pic slowed where it crashed but since it didn't make it to the post I guess I needed to provide a Lil more info.
No problem. I'm now checking it out. Couldn't find anything yet. The code seems to be fine. But there must be something, or it wouldn't crash. I'll keep searching.
