Report Tech Tool Store Bugs here
Chester170
Post by Chester170 »
Hi all. Sorry not being on the forum too much. Please report bugs you find in Tech Tool Store here.
Thanks and have a nice day! ;)
Bruno Santos
Re: Tech Tool Store Bugs...
Hey Bruno
I recently had the "Can't load database" bug.
The fix is to remove the database and reload the program. Was wondering if maybe you could make app recognize that error and just do it automatically so that we never have issue?
Chester170
Hi Jim I will talk with my dad and see what we can do!
Thanks for the report! :)
Chester170
Re: Report Tech Tool Store Bugs here
Hi guys! Just wanted to say that I'm having this problem on TTS. A lot of the tools there are not updating correctly. I wanted to know if any of you guys are having this problem. To check it, go to TTS, then settings then in the section report check there if you have any tools that are failing the update. If there are would you be so kind to report them here? Thanks in advance.
Bruno Santos
Hi Bruno,
Good to hear from you. :) I’m not having any issues with TTS and nothing shows as an issue in the report section. I hope you can find the cause and fix it. Have a great day!
Chester170
Hi Bill. It's nice to hear from you as well. It's like 20 tools or even more are failing to update correctly. And I don't know why. That's why I posted here to see if anyone else was having the same problem. Seems like the bug is only occurring to me.
