Windws 10 \BCD error
If you get a "\BCD" error on Windows 10, it can be resolved by starting up to the console and doing the following:
Step 1, Boot the device and press F11 for system recovery.
Step 2, Under system recovery, select Advanced Options
Step 3 Under advanced options choose command prompt
Step 4, When you are at the command prompt run these options :-
Bootrec /fixMBR
bootrec /fixBoot
bootrec /rebuildBCD
Once done type exit.
Step 5, reboot as normal ......... and hopefully you'll be back in windows 10 with no lost of data.
Information shared from:
http://answers.microsoft.com/en-us/wind ... 0f7?auth=1
Chester170
Re: Windws 10 \BCD error
Post by Chester170 »
I get this error on TTS. I don't know what tool is. Because when I do run it I run all the tools. I had to do an instalation pen instead of F11. Didn't know it works with F11 too, thanks Jim. I know that is a tool before avast antivirus intalation. Do you have any idea wich one? Thanks ;)
Bruno(?)
I really couldn't say for sure but that error is caused by corrupting the boot sector so I would look through the lost that you ran and see if any of the tools should have access to the boot sector and then go from there. I might also use the term "boot record" as with UEFI boot the boot "sector" is not necessarily in the first part of the drive like it used to be
Chester170
I know it's right before the AVs I just have to figure out wich one. Probably it's one tool that asks me for reboot. Right? Thanks
That could be. If it is rebooting then it wants access to files before Windows loads them so it possible it could be that one.
Chester170
Thanks for the help Jim :)
Your welcome even though I didn't give you any solid answers.
