UVKPortable
steve2189
UVKPortable
Post by steve2189 »
I have the branded version of UVK which I use on clients machines. I run UVKPortable.exe expecting it to be a portable (non-installed) app, but it installs itself, and uninstalls when you close it. Why does it do that?
(I looked through the main UVK 'info & download' page but did not see this explained)
Re: UVKPortable
Hello Steve.
UVKPortable was supposed to be provided in a zip file, but since UVK uses different files for 64 bit Windows than for 32 bit, I decided to build it into an executable package, which install the application without any prompts, and asks if you want it to be uninstalled when you close it. Otherwise I would have to create two zip files, one for x64, and another one for x86. Also the auto.update feature would be more complicated.
This way, it automatically extracts the correct files, depending on the Windows architecture, and also allows you to pass in command line switches, which will be deferred to the main application.
This has other advantages, such as being able to automatically update the package, and use of less HDD space.
steve2189
Re: UVKPortable
Post by steve2189 »
Thanks for the explanation.
