[SOLVED]Flash, Java, DirectX Updates
scottay
Post by scottay »
When I run the flash update script it says "Flash setup could not be downloaded.
DirectX and Java say they were updated, but on my testing machine Java is still prompting for an update. I can't confirm whether DirextX worked or not.
Re: Flash, Java, DirectX Updates
They must have changed the urls.
Thanks for reporting :)
I'll fix and update soon.
It's fixed with the new 2.5.0.0 version, released yesterday.
Now UVK updates the flash with the version 11 for both x86 and x64 browsers.
The Java update was fixed too.
scottay
Post by scottay »
Works like a charm, you're the best!
