Multiple Repair Tool Reports
allanc
Post by allanc »
My Clients' Tune-Ups consists of 9 SR files.
I have noticed that 3 'Repair Tool' reports are being generated in HTML format per client.
Is there a setting that I am missing that would generate just 1 Repair Tool report instead of 3?
One report would be easier for me to work with, etc.
Thank you in advance.
Allan C.
Re: Multiple Repair Tool Reports
Allan, UVK generates one report per repair operation. Each repair operation lasts until you leave the System repair section or close the application. Are you leaving the section prior to finishing the operation?
allanc
Post by allanc »
Fred wrote: Thu Feb 16, 2017 4:08 pm Allan, UVK generates one report per repair operation. Each repair operation lasts until you leave the System repair section or close the application. Are you leaving the section prior to finishing the operation?
Yes, there could be other sections of UVK that I use interspersed with SR Files.
Allan C.
If you want only one HTML report, do not leave the System repair section before all the repair operation is complete. If you need to use the other sections of the application, launch a separate instance by double-clicking UVK's desktop shortcut.
Also ensure all the SR files you load during the repair operation were saved with the Create professional report option checked. Otherwise the current report is closed when that option is unchecked.
allanc
Post by allanc »
Fred wrote: Thu Feb 16, 2017 6:55 pm If you want only one HTML report, do not leave the System repair section before all the repair operation is complete. If you need to use the other sections of the application, launch a separate instance by double-clicking UVK's desktop shortcut.
I understand and will try to remember.
What happens when UVK restarts the computer (in terms of this report)?
Also, the additional reports (after the first) are not added to the zip automatically.
Allan C.
Normally the same report is resumed after reboot. A least that's what took me a few hours to code.
