Running UVK against external hard drives only
ssavoy
Post by ssavoy »
Hello,
I just ran across UVK for the first time and I can hardly believe my eyes. I am very interested in using this software, however I do have one question.
If I take a hard drive from a seriously infected computer and connect it to my computer as an external hard drive - can I run UVK against the external hard drive ONLY and not have it run against my C drive?
Thank you!
Re: Running UVK against external hard drives only
Hi ssavoy, A bit late to reply but I'll do it anyway.
Welcome to the forums.
I think UVk will not be very helpful to identify malware in an offline HD. Apart using it to install/run mbam and SAS, configuring them to scan the external drive, and use the file tools in the UVK tools section to analyze and delete some specific files, I don't see any other thing it may help you with.
However, it can be very helpful after you delete the infected files offline and put back the drive.
