SR not displaying file path
Haven't added much in the last couple of weeks but remembered a file I wanted to add. Put in the info, saved it but needed to edit it. Re-opened it and the file path was back to the default. Closed UVK, saving the UVK SR settings, and re-opened it. Re-entered the info...same thing.
Thought, for a work around, that I would just enter the path in the UVK SR settings but it was already there. So the settings file is saving properly but it's diplaying incorrectly.
Re: SR not displaying file path
Thanks Xander. I see where that may come from. I changed that control the last update, and probably forgot that part.
I just fixed it. In fact the path is there, but you need to drop down the combobox to set it. I just made it be set by default.
