Hey,
I plugged in a USB and transferred tech tool store to the usb. Selected all applications and then pressed "update all" - waited the 1 hour for all the applications to download and update. However when I plug the device into a new PC and perform the task offline and just click "run". Application does not run, makes me "Update & Run" to use the program.
Eek. Is this a bug, or I have done it wrong?
Thanks!
TTS Support
Re: TTS Support
Hi WRC. Thanks for reporting. I'll check that out.
Re: TTS Support
WRC, I checked it out and got no issues. Here's what I did:
Please note this:
- Copied TechToolStore.exe to a USB pen drive.
- Selected a few tools and pressed Update Selected.
- Waited for the tools to update.
- Moved the USB stick to another PC.
- Ensured the same tools were selected in the second PC.
- Pressed Run Selected.
Please note this:
- By "Select", I mean tick the check box in the tool's line, not hilight the item.
- You need to run Tech tool store directly from the pen drive. Your issue makes me think you copied the EXE to the second PC's hard drive. If you do this, you'll need to copy the Tech Tools Store Tools folder, otherwise TTS will need to download all the tools again.
Re: TTS Support
Also make sure that the folder "Tech tool store tools" was transfered with the "TechToolStore.exe" just to point out the obvious.
Re: TTS Support
Thank you, Can confirm it is working correctly.
Only question I have, With the update files button, when I click that. It says no updates for applications available. However, After installing an application - It prompts me that a newer version is available. Is this just the website issue not supplying the new download package?
Re: TTS Support
Hum, it seems like an auto-update issue. I'll check that out.
