Reboot to Safe Mode w/Net during SR's third party section
Right now, I've got my SR setup doing a reboot to safe mode and I'm looking at including another app that highly recommends rebooting after it runs and, for the sake of other scanners, I want to be able to stay in safe mode w/net when it boots back up.
So....would this work?
Fix #1
Command 1: bcdedit /set {current} safeboot network
Command 2: shutdown /r
Fix #2
Command 1: bcdedit /deletevalue {current} safeboot
Also, would UVK's run-on-reboot be already active or does that only get engaged when one of the built-in reboots gets done?
Fix #1
Fix #2
Re: Reboot to Safe Mode w/Net during SR's third party section
Xander,
Yes that should work. You can just use the full path of bcdedit, in case malware has left some other bcdedit files wondering around, and tweak the shutdown command so you reboot immediately instead of waiting 30 seconds.
Fix 1:
Fix 2:
Fix 1:
%Systemdir%\bcdedit.exe /set {current} safeboot network
%Systemdir%\shutdown.exe /r /t 0
%Systemdir%\bcdedit.exe /deletevalue {current} safeboot
This is working...however, UVK isn't restarting itself when it does.
What would be a good way to ensure it restarts? Add a fix that creates a reg entry to RunOnce? And how would you add the UVKSR to it since that includes the username? Or one that calls the RebootExec app?
Xander,
At one point it did use the registry to start up but that ran into problems so Fred moved it to the startup folder.
Maybe it might could be tried again.
Weird thing is (I've been experimenting with it tonight) is that it's just inconsistent. It has started itself the last three times but missed the two before that.
Incidentally, the commands from the first post are working much better now that I've added "Wait for child processes" and a 3rd command of just "notepad" (which doesn't close itself thus preventing UVK from steamrolling on and allowing the shutdown to happen).
I was working fine the last time I tried it. If the repair operation doesn't restart, you can manually do it by executing the ContinueRepair_[UserName].uvksr.
The operation only continues if the logged-in user is the same as the one when the repair operation was started.
If you log in from a different account the repair operation does not start. In that case, you can manually start the operation as explained above, but it is not recommended, as some fixes are user related.
Yeah, that's what I had to do a few times.Fred wrote:I was working fine the last time I tried it. If the repair operation doesn't restart, you can manually do it by executing the ContinueRepair_[UserName].uvksr.
One user with no password so it does an auto-login.
Could UVK be set to run itself no matter what until the program is closed by the tech? This way, even if it's at the Welcome screen when the PC reboots, it will come back up? And, if so, be set so that it runs again even if the PC reboots into Safe Mode.
I guess I could add that as an extra option, exportable to UVKSettings.ini. Not as a standard option, obviously. I'll see what I can come up with.
Any follow-up on this?
Just working on another laptop and, once it got into safe mode, had to go into the Startup folder. What about creating a shortcut on the desktop for continuing and then UVK can remove it when the list is done?
Isn't there a RunOnce section that works in Safe Mode?
Not exactly a "section". RunOnce entries are prefixed with an asterisk to run in safe mode. That's exactly what the Reboot in safe mode and continue fix does. https://msdn.microsoft.com/en-us/librar ... s.85).aspxXander wrote:Isn't there a RunOnce section that works in Safe Mode?
That's also how it used to work in general, but there's a problem with that: RunOnce entries are handled by the shell, and as a consequence, if the File Explorer was restarted during a fix, it would launch the Continue repair operation before rebooting. Now this is even more annoying, so I used the startup folder.
If you reboot in safe mode using your own UVKSR app, it won't work, because the "asterisked" RunOnce entry was not created. It only works with the Reboot in safe mode and continue fix.
I'm currently coding the Log Analyzer in C++, and then I will do the same to UVK_en. Once I got the Log analyzer ready, I will just add the UVK requested features that won't take long to add. I don't want to waste much time with AutoIt, and then have to recode everything in C++.
I like you desktop shortcut idea better that the autorun antry. It's far less intrusive, and UVK can delete it once the repair operation is restarted. I'll do that for the next update.
Any thoughts on "autostart until we close the program"; until we actually have to "X" out the program to fully close it? UVK could put itself on the asterisked list on its startup and remove itself on its shutdown.
The problem with asterisked, or normal RunOnce entries, as I mentioned above is that they are handled by the shell, and if the Windows file explorer restarts, the RunOnce entry is executed. Since that may happen often during a repair operation, it may become an issue.
That's why I'd rather just create a desktop shortcut to continue the repair operation. But even that may be an issue, if someone double-clicks the shortcut while the operation is still in progress. I'll have to think that over.
Could it run as a service?
Win32 services don't execute in safe mode, nor do scheduled tasks. I know it's possible to make a service run in safe mode, but that procedure is detected as malware activity by most AV software. Can't really blame them. That's not the intended use of the safe mode, or it becomes 'unsafe' mode.
Which leaves us with the asterisked RunOnce entry for the "Reboot in safe mode and continue" fix, and the Startup folder shortcut, if the computer is rebooted before the repair operation completes.
We could make RebootExec run as a service while the repair operation is being performed, and make it restart UVK if it is closed by other application. Not sure that would work either, as the other application would probably kill the RebootExec process too.
