Having trouble setting up some automation
I'm looking to see how well I can automate UAK (until a premium version comes out). More of an exercise than anything right now.
I found a script elsewhere here to get the ball rolling so I'm trying to adapt it further.
<UVKCommandsScript>
;Download the Ultra Adware killer version corresponding to the current OS arch
 <UpdateSoftware> -x64
%ThirdParty%\UAK64.exe | http://www.carifred.com/ultra_adware_killer/UltraAdwareKiller64.exe
 <UpdateSoftware> -x86
%ThirdParty%\UAK32.exe | http://www.carifred.com/ultra_adware_killer/UltraAdwareKiller.exe
;64 bits automation (Run and start scan)
 <Run> -x64
%ThirdParty%\UAK64.exe /NoUpdate
->WaitWindow()
->WaitControl([CLASS:Static; INSTANCE:11])
->ClickControl([CLASS:Static; INSTANCE:11]) ;scan
->WaitProcessClose()
->WaitControl([CLASS:Button; INSTANCE:1])
->ClickControl([CLASS:Button; INSTANCE:1])  ;found # items [OK]
->WaitControl([CLASS:Static; INSTANCE:15]) ;clean
->ClickControl([CLASS:Static; INSTANCE:15])
->ClickControl([CLASS:Button; INSTANCE:1])  ;confirmation
I just can't get it to recognize anything after the Scan button and could use some input.
Re: Having trouble setting up some automation
The main problem with your script is the several instances of ->WaitProcessClose().
On the first instance, UVK will not do anything else until the UAK process ends, meaning all commands after the first ->WaitProcessClose() will be skipped.
Try removing all ->WaitProcessClose() instances except the last one.
