exe opening problem
exe opening problem
I'm unable to open UVKSetup.exe Applcation Error box pops up. Using XP Pro. Any ideas?
Re: exe opening problem
Hi RCR.
Well, for a start, what does the error message say? I just tested the UVKSetup package on XP and it works fine. The only thing that comes to mind is that your AV software is blocking the application, or the Windows XP Service pack 3 is not installed.
Missing Service Pack 3 is the problem. Thanks.
Just FYI, Windows XP is pretty much useless without SP3. Always check that first.
