I sat down to embark on my biggest scripting idea yet and it turns out that UVK may not support the #include tag from AutoIT. Is this true or is there another work around I should be looking for? The script I have works perfectly fine in SciTE but not UVK.
Was really hoping it worked cause I was really wanting to try that project
AutoIT
AutoIT
Re: AutoIT
Jim, as the documentation states,
To me, it doesn't make any difference, cause I never include any of the default files, anyway.
I once thought about using something like #Include %InstallSourceDir%\scriptname.au3, but it does not support environment variables in the #Include directive.
This is the current limitation. It may take you some time copying the constants and functions in order to make a compatible script.@ScriptDir will be the UVK's install folder. AutoIt does not need to be installed to run the script. However, if you want to #include any of the AutoIt's builtin UDFs or Constants, you will need to install it, or copy the functions and Constants to the UVK script.
Re: AutoIT
Having AutoIT installed does not seem to help as it is installed on that computer but uvk still won't run it. I will t try copying I guess and see.Fred wrote:Jim, as the documentation states,@ScriptDir will be the UVK's install folder. AutoIt does not need to be installed to run the script. However, if you want to #include any of the AutoIt's builtin UDFs or Constants, you will need to install it, or copy the functions and Constants to the UVK script.
